Old 04-22-2011, 10:02 AM   #84 (permalink)
notanarborist
Tractor - '93 Dodge Pickup W250 Extended cab Power Ram
90 day: 22.38 mpg (US)
minivan - '03 Chrysler Town and Country Lxi
90 day: 25.8 mpg (US)
HCHII - '08 Honda Civic
90 day: 49.63 mpg (US)
On diesels, fuel injection pressure is variable with load. Common rails may run at 4,000psi at idle but run 20,000-30,000psi at full load. Many boats have consumption meters that uses a flow sensor on supply and return lines. The difference gives you consumption. You would then need a computer that can accumulate that flow and divide by distance for automotive use.
