The start/stop systems I have read about use the alternator as the starter; or a belt driven starter. No solenoid and no pinion gear and no ring gear.
But belt-driven starters cause a crank bearing reaction too. The belt tension is converted to two reactions: torque (tension * crank pulley radius), and a bearing reaction, equal and opposite to the belt tension.
Coaxial electric motors, like on the Insight and the Prius, only exert torque on the crankshaft, not radial bearing load.
![](http://upload.wikimedia.org/wikipedia/commons/thumb/f/f2/Honda_Insight_IMA.jpg/503px-Honda_Insight_IMA.jpg)
