Originally Posted by Vekke
Same locking mechanism than in normal ziptie so it holds 22 kg per tie.
Or did you meant that can the tie brake on its own?
No, I was wondering about the effects of the rotational forces and vibration on the latching mechanism .
Cutting off the loose ends is probably safer than having the end of the zip-tie flapping about in the wind.
