Old 01-09-2011, 03:04 PM   #41 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
I seem to recall a fellow who did this with industrial strength velcro. I think he did this to a gun-metal VW Jetta. He blacked-out the coroplast wheel cover. He said it worked like a charm. However, I haven't seen him posting in a longgggggg time, so I don't know how long it lasted.
CarloSW2
American Solar Energy Society
Old 01-10-2011, 12:44 AM   #42 (permalink)
Originally Posted by Old Tele man View Post
...if the Velcro™ material is used 100% around the wheel-lip circumference, there certainly 'should' be enough "hold" to retain a light-weight plastic moonie.
Bingo.
Plus, moonie snugs into the inner ridge of the rim lip, so when the car hits a pothole, shock travels from lip to moonie edge, not so much via velcro. Velcro mainly keeps moonie from coming off the wheel laterally.
Old 01-10-2011, 11:47 AM   #43 (permalink)
...beats walking...
...now, someone just needs to make & sell such a setup for 16" rims (such as on our Pontiac Vibes) and I'm "sold"!
Old 04-28-2011, 01:58 PM   #44 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Is this "cool" enough?
Aluminium wheel cover attached with Ziptie Plug.jpg - Windows Live
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 04-28-2011, 02:54 PM   #45 (permalink)
Originally Posted by Otto View Post
I betcha it will: Fit the moonie disk such that its outer edge is snugly just inside the lip of the wheel rim which supports it, and use a strip of velcro around the entire perimeter of the moonie. A very light weight moonie such as the thermoformed idea noted above would impose very little load on the velcro, and be further seated inside the lip.
How would you remove the cap if it's snugly in place surrounded by Velcro? Ever try sliding Velcro apart? The sheer strength is herculean
Old 04-28-2011, 03:14 PM   #46 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
On that case you can push it out from inside the wheel. Of course it depends how big brakes you have so do you have any room to do that :/. On most cases there is plenty of room.
Old 04-28-2011, 05:57 PM   #47 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
Looks good to me !
Can the zip-ties be cut off without any fears of the disks falling off ?
Old 04-29-2011, 01:21 AM   #48 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Same locking mechanism than in normal ziptie so it holds 22 kg per tie.
Or did you meant that can the tie brake on its own?
If you use good 300x4.8mm tie no problems on that. Cheap ties can even brake in to peaces when you try to tighten them.
Old 04-29-2011, 05:08 AM   #49 (permalink)
euromodder's Avatar
No, I was wondering about the effects of the rotational forces and vibration on the latching mechanism .
Cutting off the loose ends is probably safer than having the end of the zip-tie flapping about in the wind.
Old 04-29-2011, 06:12 AM   #50 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Yes you have to cut the loose ends off. That was just a testing assembly. Rim was not even on a car yet . After two weeks I can reveal what will it look when car is ready for race.
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Moon Disc Hubcaps vs Insight Wheels 1337 Aerodynamics 42 12-18-2008 02:03 PM
For Sale: Moon Hubcaps for 14" rims swoody For Sale 10 12-03-2008 05:10 PM
14" Moon Hubcaps, trade for 15"? or sell for cash Sean T. For Sale 2 09-17-2008 04:17 PM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 05:23 PM
