Old 04-30-2011, 12:40 PM   #3 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
More info is needed! What is the engine you have in this RV, gas or diesel, does it even have fuel injection, is it's fuel injection mechanical or electronic, what size and type of RV is it?
If it was my vehicle I would say to smooth out the roof, sides and underbelly as much as possible, if it has light truck tires you can get adapted rims that allow you to put heavy high pressure truck tires on the bolt pattern for light trucks allowing you to use 80psi heavy truck tires that last longer and get better mileage then what you might have already.
It's LA so the weather is warm so you could get away with a moped or motorcycle for short trips that are further then you want to walk, or you could get public transit info and use that for odd trips.
The Following User Says Thank You to Ryland For This Useful Post:
some_other_dave (05-02-2011)
