Originally Posted by steveo126
i know this is a fuel econ forum but as a certified mechanic youre asking for a blowout. theres gonna have to be a compromise between safety and fuel economy if you value your life and those around you.
Certainly.
But the rated max. psi is what the tyres are constructed and certified for.
in no way would i ever change the psi of my tires to other than what the factory recommends
Well, on my Volvo those recommendations are blatantly wrong.
The recommended pressure for light loads - 2.3bar / 33psi - is way too low, leading to increased tyre wear on the shoulders, tramlining and an uncertain feel to the steering.
Originally, I started increasing the pressure to cure these handling and wear issues, as recommended by some folks on a car forum.
That brought me to 41 psi - still having the uneven wear issue, though reduced.
After joining ecomodder, I increased the pressure to sidewall max, 51 psi.
Guess what, the uneven wear is gone.
No alignment work has been done on the car.
I probably picked up a rubber fetish in my motorcycling years, as I fairly often feel the tyre temperature when checking them for signs of wear.
With the increased pressure and hypermiling, the tyres are a lot cooler than they used to be at lower pressures.
Yes, so much cooler that you can actually, unscientifically, feel it ...
