Old 05-02-2011, 01:02 PM   #4690 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Hi Jim! It's the Melexis HB:
Digi-Key - MLX91205KDC-HB-ND (Manufacturer - MLX91205KDC-HB)
It can be had cheaper at other places than Digikey, though.
http://media.digikey.com/PDF/Data%20...%20(rev09).pdf
Basically, the magnetic field through the sensor (from left to right or vice versa corresponds to a voltage on the output pin of the sensor. The current through the bus bar (from top to bottom) makes a magnetic field from left to right (or whatever. haha) The further away the sensor is from the magnetic field, the less sensitive the output is.
kits and boards
