Old 05-03-2011, 06:22 AM   #4 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Hi,
Originally Posted by Ryland View Post
For water heating how about using the coolant from the Prius? a pair of quick connect hydraulic fittings would work tapped in to the heater hose lines, then connect a heat exchanger, that way you are not wasting that engine heat while trying to heat water.
The exhaust heat into a gas, water heater was low hanging fruit. But there are problems tapping engine block coolant.
When the engine coolant temperature reaches 60 C, the engine comes on to maintain coolant temperature. I only want it to come on to sustain traction battery voltage. Also, plumbing adds weight to car as well as being a pumber's nightmare. <groan>
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
