Old 05-03-2011, 11:29 AM   #340 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Well the revolt's hardware is almost capable of being a battery charger. You will need to add voltage measuring inorder to be a real charger. Also, you will need to modify the firmware to ro read the voltage.
Currently the revolt is basically a constant current power supply. The duty cycle is always changing to maintain a steady current output.
You are correct about the duty cycle output. 50% duty would be 50% input voltage coming out.
Yes, As the voltage gets closer to the cells voltage, less current will flow.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
flores (05-03-2011)
