Old 01-21-2011, 03:42 PM   #331 (permalink)
jackbauer's Avatar
I did a little video today showing the charger pumping 20amps into my headway pack and hitting cv almost bang on. Yet another boring video brought to you by Bauer studios
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 02-25-2011, 09:49 AM   #332 (permalink)
ReVolt Enthusiast
Originally Posted by adamj12b View Post
The design that is currently being worked on is a Boost type PFC power supply. It takes 90-260VAC and while power factor correcting it, boosts the voltage to 400VDC and stores it in the bus.
I will try and get the schematics posted.
-Adam
Hi Adam,
How's the development of the PFC Charger going?
Did you ever get the prototype PCB that you ordered?
Hope all is well,
-Mark
Old 02-25-2011, 11:07 AM   #333 (permalink)
hello
jackbauer
It is possible to charge with your battery charger the LIPOFE4 battery
Old 02-25-2011, 03:49 PM   #334 (permalink)
jackbauer's Avatar
If you mean LIFEPO4 batteries then yes of course. Thats what its doing in the video in the post above
www.evbmw.com
Old 02-25-2011, 03:50 PM   #335 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by sawickm View Post
Hi Adam,
Hope all is well,
-Mark
Hey Mark,
Big post coming on both threads. Probably tonight.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 02-25-2011, 04:17 PM   #336 (permalink)
how do you configure the charger for the lifepo4 battery.
Old 02-26-2011, 01:10 PM   #337 (permalink)
Hello
jackbauer
On your video I can see that is no more blinking LCD display. Do you have the new FW for the charger. Besause when I switch my charger every light in my home blinkig on the 1 second
Old 03-09-2011, 08:54 AM   #338 (permalink)
Hey Mark,
-Adam
I have posted an update on my thread.
http://ecomodder.com/forum/showthrea...res-13013.html
I will be starting research on PFC as well over there for those interested.
-Adam
Old 05-03-2011, 11:22 AM   #339 (permalink)
EV Connoisseur
Dumb question
May I ask a probably dumb question:
If I use the open revolt controller as a voltage controller for a charger then the PWM duty cycle would control the voltage that is put out, right?
At 50% duty cycle an 100V input would result in an output voltage of 50V.. in theory...
If I have a Lithium pack with a BMS, for the balancing phase of the BMS the amps must be maximized at 3A.. how can that be accomplished?
My theory is that when I have one cell that is 3.2V nominal and 4.0V max if I charge it with 4.2 volts the amps would be 10A or so.. and the only way to control the amps is to lower the voltage.. say at 3.9V charging voltage the amps would be 2A..
Is that how it works?
Old 05-03-2011, 11:29 AM   #340 (permalink)
Well the revolt's hardware is almost capable of being a battery charger. You will need to add voltage measuring inorder to be a real charger. Also, you will need to modify the firmware to ro read the voltage.
Currently the revolt is basically a constant current power supply. The duty cycle is always changing to maintain a steady current output.
You are correct about the duty cycle output. 50% duty would be 50% input voltage coming out.
Yes, As the voltage gets closer to the cells voltage, less current will flow.
-Adam
The Following User Says Thank You to adamj12b For This Useful Post:
flores (05-03-2011)
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 10:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 12:23 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 04:10 AM
