Back from getting new front tyres and an alignment.
My wheels should be toed in by 1.5mm according to the shop guy (+\-1mm) and they were at 0mm and 2mm toe out. I had that fixed - both are around 1mm toe in now. It could be me, but the car seems less twitchy and doesn't pull at all!
I saw a reasonable camber on the wheel. I am not sure what to expect to see - I know there should be some. Any way I can measure it? I will be back in the shop so I can maybe ask them when I get the uniroyals in. I should have taken a picture for you folks!
Is front camber tricky to adjust? Will I offset the alignment of the wheels if I have a go at it? Shims or something? Back wheels look straighter.
Cheers for all the help so far!
Mike
