Thread: VW Rims
Old 05-03-2011, 02:42 PM   #8 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Christ View Post
Steel probably is heavier by a good margin. You can sort of fix this by going to a smaller wheel with a slightly taller tire to keep the same circumference, but unless you drive mostly in the city, the impact will be minimal.
If you're worried about resale, go to the junkyard and buy a set of steel, clean them up and paint them, and keep your alloy around.
When you sell the car, the extra set of wheels will actually increase the take price, AND you'll probably keep the smoothies, so you can put them on the next wreck you buy.
Some of us in snowy climates have our winter tires on extra steel wheels. You can buy new tires mounted on steel wheels at Tire Rack if you are going to a narrower tire size. FWIW, I have had trouble with some hubcaps, like the ones in your original post, coming loose. If you are getting junkyard rims, you could go with the aluminum racing disks and drill and tap the outside edge of the rim, and bolt them on. The tire bead covers and seals the holes.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
