Old 05-04-2011, 09:06 AM   #4695 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by Camaro View Post
I've been trying to get through this thread, but it's just to long. I've built the 500 amp controller from Paul's kit, but I can't get the source code posted on the Wiki to run.
I'm using Programmer's Notepad with AVR Dude, and Sparkfun's Pocket AVR Programmer. I can program the 168 fine, I've written my own code to test the LED, UART, and ADC. It's not a programmer or communication problem, it's something with the Paul's code (or the way my complier interprets it). I'm a fare programmer but for the life of me I can't figure this out. I've take the code from the wiki, add this:
int main(void)
int x;
unsigned tm_show_data;
unsigned char cmdpos, cmdok;
char cmd[32];
char str[80];
DDRD = 0b11000000;
PORTD = 0b01000000;
but the idle Led never lights up.
Has anyone else used my same setup? Any advice? Thanks guys...
PS. Is there a controller help thread where I should have posted this?
Is there a special reason you want to compile your own firmware?
If not, I suggest you just download it from my website. Index of /firmware
They are already compiled and tested. Its a full archive of all the versions of FW.
Im not sure why it wont blink the LED.
Try this out.
Code:
#include <avr/io.h>
#include <util/delay.h>
#include <avr/iom168.h>
int main (void)
	DDRD = 0xFF;
	while (1) {
		PORTD = 0xFF; //Set PORTD high
		_delay_ms(500);
		PORTD = 0x00; // Set PORTD low
		_delay_ms(500);
	return 0;
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
Camaro (05-04-2011)
