Recalculated everything so that it's best by 3200 rpms. Using 98 hp as the goal ( 1 hp/ cu in. at 3200 rpms, it'll rev higher than this and still pull to 4000, but now the powerband is real bottom heavy )
13.65 pounds per minute of airflow
18.95 psi boost gauge pressure ( 33.66 absolute )
Pressure ratio is 2.60
So it looks like a GT15 sized turbo will still work with a little more boost.
There weren't any maps available on the website so an exact match couldn't be made, but I'll make a phonecall.
