Old 05-06-2008, 02:12 AM   #23 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
There is only one draw back to using K&N filters or re-usable filters that require oil. And that is the oil. If improperly serviced that oil will get past the filter and begin to muck up your MAP sensor on the intake and those are not cheap. If it does not mess it up enough to throw a code, then it just affects the air fuel mixture which impacts your FE.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
