Old 05-06-2011, 09:39 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
If you are just trying to smooth out the readings on a vacuum gauge, you might just try a restriction by the engine side of the hose so that the hose itself acts as an "accumulator". Don't put something together that the engine can injest. Maybe a bit of dowel rod shoved in the hose that you drill out progressively till you are happy with the readings.
