Thread: Swift brick?
Old 05-06-2008, 05:41 AM   #25 (permalink)
Arminius
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Originally Posted by Harpo View Post
With Upper Grill Block, I've noticed that below 50-55mph the drops that form below the wiper at rest migrate with the flow over the hood fairly uniformly. However, after 55mph it appears that some turbulence (at least non-laminar flow) sets in forward of the wiper, actually causing the dops to stagnate, and sometimes retreat to toward the front. I can't determine whether it's a function of the wiper blade interference drag at that speed, or just that the airflow changes off the hood making a low pressure area just forward of the lower windshield.
It would be intersting to witness it without the Upper Grill Block to see if it's altered.
That's interesting. I couldn't sleep, so I got up an poked around. I noticed that both wipers can be lowered below the hoodline with a minor adjustment of an 1+ inch on the passanger side and 2 inches on the driver's side. Of course, I will need to make sure they don't hit each other or the base beneath the window. But it looks doable, and nothing but the base of the wiper arm will be in the path of the wind. All said, it's probably too difficult to measure the results, but it's worth a try.
