Old 05-06-2011, 11:56 PM   #260 (permalink)
kawboyCAFE
NinFo - '09 kawasaki ninja 250R
Originally Posted by scorch View Post
the best i've gotten on my 08 ninja 250 is 89mpg. And average about 68mpg....For the 89 i was really trying to see if i could hit 100, but i dont think its possible . kept it under 50mph which is my commute most of the time anyway....I recently changed sprockets in the hopes to see 100mpg
it would be really hard to hit 100 mpg on the newer ninja 250, unless you took the cams from the older ninja 250 and swapped them. but with the stock setup, maybe 90 with seriously easy driving. your 89 mpg is probably the best you will get, and i still dont see how you did that.
if you drove steady at 35 mph, in top gear, after putting on 15/42 sprockets, for 3 hours, then maybe you could get 100 mpg. but man, would that be boring.
