Old 05-12-2011, 12:00 AM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by jedi_sol View Post
Hey! Southern OC, kinda my neck of the woods. I'm around Tustin/Irvine area. My daily commute is the 5 freeway between the 55 and sand canyon/5.
I know that route pretty well, having lived in Santa Ana previously. The 55/5/405 was my test loop for my WAI test last month.
Southbound is a very slight uphill grade, so my mpg is good, but not great. However, going Northbound, depending on traffic, I can get home in only 2-3 pulses while EOCing the whole time.
I have similar scenario, in reverse. The elevation above sea level increases from home to work. My big milage gains are coming home.
Bumpstarting, perhaps you are popping the clutch too slowly? Make sure you are in 5th gear. For me, popping the clutch quickly hardly creates any jolt whatsoever.
I have been using 5th, 4th, and even 3rd at times--depending on speed. On the way home tonight I took this advice and used 5 exclusively. I think it is better.
