Sounds about right, stock G10s don't start to pull well until the RPMs get up there, you can either switch to an XFI cam or get a gear (or drill your own) to advance the stock cam (10 degrees works nicely, one tooth on the pulley is 18 degrees, a bit too much...).
Good to hear you survived what could have been a much worse situation.
