Old 05-12-2011, 01:29 AM   #8 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by California98Civic View Post
I have been using 5th, 4th, and even 3rd at times--depending on speed. On the way home tonight I took this advice and used 5 exclusively. I think it is better.
That's what causing the jerkiness when you bump start. You always want to use 5th gear for a smooth bump start. Think of it this way. if you are driving 20mph and you want to bump start, 5th gear will be the lowest rpm when you pop the clutch. So there will be less jerkiness. Now imagine if you wanted to bump start in 3rd gear. The rpms would be higher. So when you pop the clutch, the transmission jerks the engine up to that higher rpm, hence the jerkiness.
I've bump started in 5th all the way down to 10mph.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
