Old 05-13-2011, 09:01 PM   #13 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
I know it's off topic but on topic. Your transmission has 4 range changes with a lockup convertor, so theoretically 5 speeds. The thought is if your engine got something like a tow / economy tune up, boosting the bottom end torque and modifying the shift points and torque convertor lockup to match the power curve, it'll perform better than swapping a transmission, and be a far sight cheaper and less complicated.
EDIT- Looks like someone beat me to the punch on the chip tune.
Look up Illinois Dyno Center as one possibility and the TDIClub has plenty of knowlege about what works and doesn't.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
The Following User Says Thank You to cleanspeed1 For This Useful Post:
SwamiSalami (05-13-2011)
