Originally Posted by Arragonis
Are you sure they are draining it and not just sucking it out using one of those quick oil change machines ?
When I went in to have the high oil level corrected, they talked about sucking out some oil, so that could be their method of getting out the oil.
But apparently, Citroen warns not to do that on the 1.6HDi.
Oil needs to be drained by gravity while warm; with filter, filler cap, level probe and drain all opened up.
My old Pug dealer in England used them all the time and had quite a few Turbo failures over the years.
They seem to have been failing Citroen as well.
C4owners: FAQ : 110 : C4 1.6 HDi Turbo Failure
