I had my longest distance on the 270th fill up: 574 miles! But, at 11.50 gallons it was also the most gas I ever pumped into the tank, so the MPG was 49.95.
Yikes ! Could it be that you only had 0.4 gallon left in the tank ? My echo has a 11.9 gallon tank, so I am assuming your xA has the same capacity.
Are you aiming for a 600-mile tank ?
