Old 05-17-2011, 01:15 PM   #13 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by winkosmosis View Post
The best space to leave open would be the lowest and most central. So it would make more sense to put shields in front of the top grill and the foglight openings, and leave the bottom center open.
+ 1 !
That's why I was asking about the upper grille blocks.
They won't help the (radiator) cooling very much, but often take in a lot of air.
A front plate is not required in NC and actually, there is no reason for it other than I like it. I realize I should see a small gain if I remove it.
It's blocking part of what usually is the most effective area to let in cooling air - the lower central opening.
