Relatively minor, but annoying issue.
When I go to the home web site, I would typically select forums. At the forum screen when I type in my user name at the login, it doesn't find the login/password I normally would expect. It finds whoops, instead of Whoops, with no password. When I select recently posted and then try to login, it will find the correct name, pull up the correct password and let me login.
This has taken me several trips around the block before I could figure out what I was doing different, when it would let me login and when it would not.
