Old 05-22-2011, 11:30 PM   #4780 (permalink)
Camaro
Agreed, I'm not saying Microchip is better, its just what I'm using.
Speaking of which, I've got revision 1 of my controller code done. It should be attached. I've also attached photos of my setup testing it. It works, but its definitely not done.
Please give me comments on my code. It's probably not written the best but I try and make it understandable.
I do have questions about the thermal resistor and the current sensor. What's the volts per degree and volts per amp for the two sensors? Looking at the data sheet for the LEM HASS 300 it looks like 0.625 v/a
ID:	8434   Click image for larger version
File Type: zip HighPowerController (2).zip (436 Bytes, 66 views)
The Following 2 Users Say Thank You to Camaro For This Useful Post:
deodeo (04-20-2012), dneale (06-22-2011)
