Originally Posted by PaleMelanesian
Why don't you think the Scangauge works well on our cars? I use one and it seems to work in my civic. As long as it's not the lean-burn HX it works well.
I guess I was mistaken. When I was looking into a gauge a few months ago, I went first to the ScanGauge site, and I thought it said my 98 DX was not compatible, so I bought the UG. That said, I have not gotten accurate readings on MPG from the UG yet--if accurate means correspondence to my odo/miles/pump calculations. Right now I am not yet sure if it is a calibration problem or due to other mechanical and pump variation factors that have lately bugged me a little. A question: MPGuino can be run at the same time as a UG, I think, right? The guino does not plug into the OBD port, no? Would it be advisable to run both, or should I just keep trying to calibrate the UG.
