To take full advantage of different injectors you should have the injector profile changed in the PCM. The reason for this is that injector lag time, fuel flow, and initial injections may all be different causing other settings to be off and having the injector spray event happening a little early or late.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
