If I could find something wrong with it to fix, it all functions as intended except the vent which gives very little flow w/o the fan on and not much more with it. The heat works great, the AC never has worked and I've cleaned what few leaves there were in the cowl out already.
Mind you I'm used to 70's era trucks that will just about blow you out of the cab with the vents so maybe it's just a problem of expectations being too high...
