Check the break off pressure on the injectors. If it is not up to spec then you get poor atomization and that could be a contributor to your noise and possibly even some of the smoke.
On MB the spec was around 1800 PSI. You can shim them or replace the springs and it will make a vast improvement.
regards
Mech
