Old 05-24-2011, 01:38 PM   #148 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
THAT'S a turbo... It weighs about 50lbs, and is VNT and twin scroll.
The VNT section is electronically controlled, not sure how to take care of that if I were going to attempt to use it.
The TE04H that I bought seems to be reasonably intact, I just need that clamp for the CHRA, because I don't want to run it without it. Once there is oil pressure on the bearings, the play in the shaft should be minimal.
