Old 05-24-2011, 07:28 PM   #25 (permalink)
usergone
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
If you go the route of alternative fuel, the first thing to worry about is filtration. You don't want gunk and particles getting pumped through your injection system. Next is viscosity: if you get the blend too thick, you'll stress your seals, underfuel, and risk cavitation in the IP. Kerosene is a common "cutter" but I just use #2 diesel.
In an IDI you can run about a 50:50 blend of clean wmo and diesel, with no modifications. I don't have any experience with veggy oil.
The only time I have had trouble with WMO is when I was making a bunch of short trips that barely got the engine warm. The injectors had plenty of of carbon caked on the tips, hurting atomization.
The Following User Says Thank You to usergone For This Useful Post:
War_Wagon (05-25-2011)
