Thread: WAI commentary
Old 05-25-2011, 12:30 PM   #6 (permalink)
Daox
Nope, it keeps the ratio at stoichiometric. The result is lower power output for a given throttle opening. To maintain speed, you must therefore open the throttle further. This decreases pumping losses which increases efficiency. Also the warmer air promotes a faster burn I believe, which leads to higher peak cylinder pressure and additional torque.
