Old 05-25-2011, 05:45 PM   #73 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
snow tires
Here's the car wearing its winter boots & looking funny without the OEM wheels...
They're one size off the OEM tire (taller - 70 vs. 65 OEM aspect ratio), but I'm OK with that.
Gently used set of four, on steelies... with wheelcovers! 160 bucks.
Nokain Hakkapeliitta 1
165/70 R 14
81 T (what's that mean?)
M + S Unidirectional tread
Max load 462 kg (1019 lbs)
Max pressure 300 kPa (44 PSI)
Plies: Tread 1 nylon, 2 steel, 1 polyester
Sidewall 1 polyester
Too bad they're not the special low rolling resistance "Hakkapeliitta R" winter tires that Chang Ho Kim used on his CRX to win the AMEC fuel economy run!
(See: Modified Honda CRX HF Scores 118 MPG in Fuel Economy Run | Hypermiling, Fuel Economy, and EcoModding News - EcoModder.com )
ID:	8461   Click image for larger version
