Old 05-27-2011, 01:05 PM   #35 (permalink)
LinuxGold
1999 Honda Civic HX 5MT
LinuxGold's Avatar
Originally Posted by Drew View Post
Hey I just read through this thread,and wow it's just what I've been trying to find. I have a 99 civic hx and want to put a guage in to monitor the lean burn. I'm on a work computer so the pics must be blocked because I cant see any of them. I'll look at home this evening. Do you guys like the MPGuino or ScanGuage? How well do they work with the lean burn engine?
I would recommend MPGuino for the best MPG readout because scangauge is set to fixed 17:1 air to gas mixture ratio. The VTEC-E uses 22:1 air to gas mixture on the first stage which gives scangauge incorrect read-out. Scangauge reads the Fuel Injection timing, not scangauge.
