Old 03-14-2011, 02:47 PM   #31 (permalink)
1999 Honda Civic HX 5MT
LinuxGold's Avatar
Abadoned Mpguino for scangauge II --
Still in calibration stage -- so far 66.2 MPG 8.4 miles segment.
Old 04-01-2011, 03:46 PM   #32 (permalink)
HX1 - '98 Honda Civic HX
90 day: 48.08 mpg (US)
PriusG2 - '09 Toyota Prius II
90 day: 47.91 mpg (US)
PriusG2-MFD - '09 Toyota Prius II
90 day: 50.3 mpg (US)
Volt1 - '14 Chevy Volt
LinuxGold, please post your calibration results once you are happy with them.
I am running 13" tires from a hatchback on my civic so my VSS calibration is different, but my fuel is set to 290000000 right now.
Prius MFD fuel Log
Prius Gallons at fill up Log
Old 04-04-2011, 08:27 AM   #33 (permalink)
LinuxGold's Avatar
I abandoned mpguino for ScanGauge II, there were no calibration needed for ScanGauge II, there are always small variations.
So far I am currently on Tank of 62.5 mpg 183 miles (2.93 gallons) so far with 568 miles/9.1 gallons remaining.
My high segment is 76.8 mpg @ 2.2 miles
Old 05-27-2011, 11:49 AM   #34 (permalink)
Hey I just read through this thread,and wow it's just what I've been trying to find. I have a 99 civic hx and want to put a guage in to monitor the lean burn. I'm on a work computer so the pics must be blocked because I cant see any of them. I'll look at home this evening. Do you guys like the MPGuino or ScanGuage? How well do they work with the lean burn engine?
Old 05-27-2011, 12:05 PM   #35 (permalink)
LinuxGold's Avatar
I would recommend MPGuino for the best MPG readout because scangauge is set to fixed 17:1 air to gas mixture ratio. The VTEC-E uses 22:1 air to gas mixture on the first stage which gives scangauge incorrect read-out. Scangauge reads the Fuel Injection timing, not scangauge.
Old 05-27-2011, 04:30 PM   #36 (permalink)
I have both mpguino and scan gauge 2. I like both, but I like having the mpguino in my hx all the time. I keep the scan gauge in my truck to monitor timing and temps mostly.
Prius MFD fuel Log
Chance to replace my Civic EX with a Civic HX ZachUA General Efficiency Discussion 12 05-10-2009 11:24 AM
Wanted: Civic HX 4 replacement or Civic shell needing an engine HDCaptain For Sale 1 03-14-2009 02:57 PM
EcoMod Lurker needing help with wrecked Civic HX HDCaptain Introductions 7 12-08-2008 07:55 AM
96 Civic DX HB vs civic HX EngineeredCivic EcoModding Central 4 09-21-2008 08:30 PM
Civic HX or DX GregM EcoModding Central 7 07-22-2008 10:27 AM
