Old 05-27-2011, 07:33 PM   #1 (permalink)
minimotos95
wagovan - '89 honda civic wagovan
90 day: 34 mpg (US)
mini - '05 honda crf70f
90 day: 69.13 mpg (US)
fifty1 - '08 yamaha ttr50e x
90 day: 84.62 mpg (US)
RT4WD - '87 Honda Civic wagon RT4wd
fifty2 - '05 Honda CRF50F
wagovan in colorado
i figured i should join this forum.
i have a 89 honda civic wagovan(a real wagovan not a DX or RT4WD). i am wanting to get even better gas mileage.
i just measured my mileage for the first time, 31.5mpg 85% city 15% offroad
so far on my to-do list is:
taller tires on lighter wheels... rota auto X or konig helium with A/Ts would be ideal
find a d16 longblock, current d15b2 burns oil in #2 and #4.
down the road:
turbo setups increase gas mileage so long as you keep it out of boost, correct? or does that only apply to diesels?
if so i am considering running something that wont make boost till about 4kRPM. i kind of doubt a civic will be able to spool a turbo at any lower RPM so it should be easy to find a good turbo for that setup... hot pipe or small stock DSM SMIC for simplicity, extremely low boost like 5psi
pictures are attached because apparently you need 5 posts to use photobucket on here
as you can see in the third picture i have things to decrease my gas mileage too
ID:	8498   Click image for larger version
ID:	8499   Click image for larger version
ID:	8500   Click image for larger version
