Old 05-28-2011, 05:40 AM   #91 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by jedi_sol View Post
Since temps do not fluctuate very much for underground tanks, will temperature flucuations have a significant impact on the gas in my fuel tank, in terms of volume? Or are the changes so miniscule, it's not even a factor?
The expansion factor for gasoline is 0.00106 / °C.
If you heat 1 gallon of gas 20°C, it'll expand to 1.0212 gallon.
(Say 10° underground storage temperature vs. 30°C tank temperature.)
That's a 2% difference.
Will that affect how much gas I can fill up? Would this cause underfill/overfill?
It's not dramatic, but it definitely affects the fill-up in warm weather.
The key factor is not what goes into the tank, but what fuel is still in there.
Filling up with a lot of expanded fuel still in the tank, would show a lower amount of fuel going in, and show artificially better mpg.
The Following 2 Users Say Thank You to euromodder For This Useful Post:
jedi_sol (05-28-2011), Piwoslaw (05-28-2011)
