05-28-2011, 04:27 PM
#46 (permalink)
lift
Originally Posted by winkosmosis
Those amounts of lift are tiny. The reason the paper experiment convinces people that planes fly through the Bernoulli effect and not airflow turning is because the paper is so light for its surface area.
If the Bernoulli effect really was that strong, you could tilt a flat plate downward into airflow, and it would generate lift at any angle up to the point that flow turning balances it out.
What about those Bonneville Salt Flats spoilers? Fast airflow on top, virtually no airflow below. So do they create lift?
They create negative lift.They 'spoil' the lift.
