Old 05-28-2011, 10:14 AM   #41 (permalink)
The PRC.
Bernoulli sucks.
Literally.
The Following User Says Thank You to Arragonis For This Useful Post:
Christ (05-29-2011)
Old 05-28-2011, 02:59 PM   #42 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
Originally Posted by winkosmosis View Post
An analog would be a car... Remember the Audi TT lift fiasco? Even at zero chord angle, a car can have dangerous lift, necessitating spoilers. It's not because air flows faster over the top of the car, but because of the angle of the sloping windshield and trunk. If it was Bernoulli, the little spoiler that they added to the trunk wouldn't have solved the issue.
Heck... if Bernoulli was that powerful, cars with air dams preventing much airflow underneath would lift off.
oh dear.
first the audi solution generates seperation to kill lift a the rear most point, the phase 1 TT still generats lift, just not as much.
as for airdams they limit the flow under the car which is accelerated as it leave the underside and resumes normal flow therefore the flow is faster than the upper surface .
I thinking you really need to seperate Benoullis law from the longer line theory.
lift is resultant from benoulli lift and downwash lift
nealy every single car on the road produces lift.
if you don't fancy the paper trick mentioned earlier try hanging a spoon between you forefinger and thumb with the head hanging down loose enough to wobble. now run your fosset and put the curve back into the flow. ok, now repeat with the dished inner side - 9times out of 10 depening on the spoon the back will get more movement than the dish.
Benoulli works - long line is Boll***s
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 05-28-2011, 03:23 PM   #43 (permalink)
The PRC.
Fossett - forcet, i.e. tap - I think.
Old 05-28-2011, 03:50 PM   #44 (permalink)
Originally Posted by Philscar View Post
Stand on your bathroom scale.
Hold hair dryer in your hand and point it at your forehead.
Run blow dryer on cool setting(don't fry your brain).
Check weight before and after.
If you get lighter with wind blowing over your head,you are developing lift!
Sailboat sails develop lift .
Airplane wings develop lift.
Cars develop lift if they are shaped like a wing.
Tape a sheet of paper to a table edge with most of it hanging down.
Blow some air over the table in the direction of the paper.
Shazam! The paper lifts up!
Lift caused by the airflow faster over the top than the bottom.
I rest my case........
Phil
Those amounts of lift are tiny. The reason the paper experiment convinces people that planes fly through the Bernoulli effect and not airflow turning is because the paper is so light for its surface area.
If the Bernoulli effect really was that strong, you could tilt a flat plate downward into airflow, and it would generate lift at any angle up to the point that flow turning balances it out.
What about those Bonneville Salt Flats spoilers? Fast airflow on top, virtually no airflow below. So do they create lift?
Old 05-28-2011, 04:22 PM   #45 (permalink)
Diesel
I refer you to my earlier comment
Old 05-28-2011, 04:27 PM   #46 (permalink)
lift
They create negative lift.They 'spoil' the lift.
Old 05-28-2011, 05:28 PM   #47 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Errr ... the Coanda effect works.
Old 05-29-2011, 12:00 AM   #48 (permalink)
And why is that?
To clarify: Why does a flat plate, with air flowing quickly over the top of it, and no airflow below it except sneaky eddies spilling around, spoil the lift created by the sloping rear window of the vehicle?
Old 05-29-2011, 06:52 AM   #49 (permalink)
Diesel
Overall - it counld be used to extend the chord lenth of the body flowin through the air and therefore reduces the relative camber of the top surface but bonneville 'spoilers' don't create downforce or negative lift - they reduce aid the laminar seperation of flow from the rear of the vehicle. You've choose a bad example there mate. sorry
Old 05-29-2011, 02:26 PM   #50 (permalink)
I didn't choose a bad example. I said they don't create lift, even though flow is fast over the top and nonexistent (or almost) below. If the Bernoulli effect is as powerful as some believers in the myth think, a spoiler like that would increase lift.
