Old 05-31-2011, 06:24 AM   #167 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Arragonis View Post
PW - do you have more detailed pics on the seperation you did of the intake, intercooler and so on behind the grill please ? I'm trying to get my head round whether I need to open the front grill block or not - warm intake or cool ?
Here is the plastic cover which goes over the top of the rad/IC. You can see the hole I covered under the intake scoop and the plastic tab I put in the IC side of the upper grille:
Without plastic cover:
Top view:
Close up of the top of the intercooler. Notice the black OEM plastic wall on the left.
Looking down you see the OEM bottom cover:
Close-up of the IC's grille block. I recently added an extra opening on each side, but I plan to make the openings taller:
Even-closer-up:
ID:	8534   Click image for larger version
ID:	8535   Click image for larger version
ID:	8536   Click image for larger version
ID:	8537   Click image for larger version
ID:	8539   Click image for larger version
The Following User Says Thank You to Piwoslaw For This Useful Post:
Arragonis (05-31-2011)
