Old 05-31-2011, 07:06 AM   #168 (permalink)
Arragonis
The PRC.
Thanks - that helps. I couldn't quite figure out what was added but I see the plastic cover in pic 1 and removed in 2 was OEM ? I'll need to add something similar to cover the entire section between the radiator top panel and the grill.
Did you block the IC cover for aero or for heat ?
