Old 05-31-2011, 11:25 AM   #17 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
If you add a switch to keep the car from starting I would place it in line with the fuel pump or injectors. The reason for this is if the car does not start at all they might think to look for a switch especially if the electronics some on in the car, if you keep fuel from getting to the engine it will try to turn over but not start like the car ran out of gas.
I'm not sure where the fuel pump fuse is on your car but if it is in the cab then that would make it easy to add a switch.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
