Originally Posted by khafra
The problem with buying 5gal of B100 and mixing my own is that water also seems to be very bad for the hpfp. B100 is highly hygroscopic, and here in Florida we have around 120% humidity most of the time. I'd never be able to use up the biodiesel before it was 50% water.
Do you have a list of states that mandate B1, or some reference? I'd like to know if FL is included, and I'm having trouble finding anything authoritative.
Do a google search on that or Biodiesel Magazine. I will do the same.
Brake fluid absorbs water at an alarming rate, but as long as it's in a sealed container it's fine. Also w/ BioD water settles to the bottom esp if it's fuel grade quality.
