Old 01-10-2011, 12:26 PM   #11 (permalink)
...beats walking...
...does this mean the Diesel Pumps will have to have a "Best if Used by..." date (wink,wink)!!!
Old 01-13-2011, 09:39 AM   #12 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
Tele,
Too Funny!!!!!!!!!!!!!!!!
Old 05-28-2011, 01:29 PM   #13 (permalink)
The storage question is relevant to me as well. Ever since reading about the ruinously expensive hpfp problems caused by caustic diesel, I've been looking for b1, b2, or b5--but all I can find is b100 sellers 40 miles away who are hard to get in touch with.
I'm not even sure I'll be able to buy it in quantities as low as 3 gallons--which should be a six month supply at b2 mixing rates. Where do people normally get this stuff?
Old 05-28-2011, 05:51 PM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
What car do you have ?
In Europe, all regular pump diesel is B5 these days, so you can safely run a 5% blend.
Old 05-28-2011, 11:19 PM   #15 (permalink)
I'm confident that both b2 and b5 will work in my mkvi golf tdi--but i can't find either of those here in Florida. There seems to be no list of stations that provide them, only a list for b20 and up--and that's a very small list.
Old 05-29-2011, 06:29 AM   #16 (permalink)
euromodder's Avatar
The Mk. VI is the current model, so it probably comes with a diesel particulate filter ?
A DPF rules out B100 with the current set-ups
What biodiesel blend you can run can be found in the car's manual.
You'd be better off getting good quality B100 and make your own blend.
Old 05-31-2011, 09:09 AM   #17 (permalink)
Just fill up a few 5 gallon containers & mix it yourself. Almost all states have mandated a B1 at least for the REG D2. That was according to Biodiesel magazine of last year. Some states even higher mandated mix!
Dave
Old 05-31-2011, 12:47 PM   #18 (permalink)
The problem with buying 5gal of B100 and mixing my own is that water also seems to be very bad for the hpfp. B100 is highly hygroscopic, and here in Florida we have around 120% humidity most of the time. I'd never be able to use up the biodiesel before it was 50% water.
Do you have a list of states that mandate B1, or some reference? I'd like to know if FL is included, and I'm having trouble finding anything authoritative.
Old 05-31-2011, 03:40 PM   #19 (permalink)
Do a google search on that or Biodiesel Magazine. I will do the same.
Brake fluid absorbs water at an alarming rate, but as long as it's in a sealed container it's fine. Also w/ BioD water settles to the bottom esp if it's fuel grade quality.
Old 05-31-2011, 03:53 PM   #20 (permalink)
Under State Biodiesel Mandates,
There seems to be only 7 states that currently have legislation. Fl. is not one.
But this went into use in Jan 1, 2010. More states were hopefully on the way.
Advanced engine-control system reduces biodiesel fuel consumption and emissions vtec-e Fossil Fuel Free 0 01-26-2010 07:58 AM
How much impact biodiesel has on FE? Eddles Fossil Fuel Free 1 05-05-2009 02:18 AM
Biodiesel resources in Los Angeles? cfg83 Fossil Fuel Free 0 07-02-2008 04:30 PM
Call To Action! Please Help Save AZ Biodiesel SVOboy General Efficiency Discussion 4 05-02-2008 06:56 PM
