I want to do the kill switch tonight. Is this the best way to do it?
--Easiest for you is an injector kill. There is a single power wire that feeds a resistor box, it's the only wire on the box that is a different color. The box is a finned aluminum case mounted on the drivers strut tower.
Switch inline with the different colored wire will kill power to all four injectors. This assumes you mean the CRX.--
Thanks for the help..
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
