Old 06-01-2011, 11:40 PM   #172 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by nichols735 View Post
dragging up some thing way way back in this thread, but EGR = BAD for FE!
EGR is for NOx emissions, not for FE. It often has very little moving parts itself because airflow through it is regulated by a throttle someplace else on the engine. If you have EGR, get rid of it, if you dont DONT ADD IT.
by the way, the adjustable grille is awesome. I am going to "borrow" some ideas from that.
This is a pretty strong first post... Do you have any references to back up your claims?
Edit: Clearly, you're referring only to EGR on a diesel engine, correct? If that is, in fact, the case, disregard my call for references.
