Originally Posted by botsapper
Very viable. Some alignment concerns because of the tapered sides. It would require wider track platforms for the two sliding shells. Weather-seals around the top & sides. Lock down pins and you're good to go.
Use as your idea board and good luck on your project.
Your CGI skills are first rate. A picture is worth a thousand words. Very cool!
