Old 06-01-2011, 02:40 PM   #11 (permalink)
PSmodder lurker
Very viable. Some alignment concerns because of the tapered sides. It would require wider track platforms for the two sliding shells. Weather-seals around the top & sides. Lock down pins and you're good to go.
Use as your idea board and good luck on your project.
The Following 3 Users Say Thank You to botsapper For This Useful Post:
KamperBob (06-02-2011), NeilBlanchard (06-03-2011), slowmover (06-11-2011)
Old 06-01-2011, 03:38 PM   #12 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Nice pics! I'm not sure if I'l actually make the sections telescoping. For one thing, I don't like the sudden steps (which would be necessary if the sections telescoped). Maybe someday, but right now I'm trying to keep things simple, study, and practical. I'm thinking 3 fixed sections and using some rubber strips (maybe weatherstriping) to overlap the joints and keep the water out--attach the stips to the front section and overlap the rear section.
Old 06-01-2011, 07:58 PM   #13 (permalink)
It sounds like a good idea to me, and fairly do-able.
Old 06-01-2011, 08:47 PM   #14 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Kinda reminds me of the AirZooka...
ThinkGeek :: Airzooka Air Gun
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 06-02-2011, 06:59 AM   #15 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Your CGI skills are first rate. A picture is worth a thousand words. Very cool!
Recreation Engineer
Old 06-02-2011, 11:36 AM   #16 (permalink)
Ok, so my drawings aren't nearly as pretty, but here's the general shape that I thinking of. I still have to re-draw the rib profiles into my 3-section idea. Basically what I did is slope the center peak downward at 11 degrees and slowly transition from the cab shape to a sideways half-oval shape. This way there are no steep transitions.
ID:	8602   Click image for larger version
ID:	8603   Click image for larger version
ID:	8604   Click image for larger version
Old 06-02-2011, 01:42 PM   #17 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Take a look at the hinged aero topper I built for my truck. Photos are in my profile. It is built in four pieces that bolt together. The top can be removed in a few minutes - unplug wire harness, unclip the gas struts, pull hinge pin, lift off.
The largest (and unexpected) benefit is that I can stand under it when loading stuff.
Old 06-02-2011, 02:51 PM   #18 (permalink)
JR, I like your cap. It looks really sharp! No offense to some of the others who have put together aero-caps, but I want something that doesn't look like some garbage duct taped together.
What type of epoxy did you use? Did you use 1 or 2 layers of 1/4" plywood?
Old 06-02-2011, 10:05 PM   #19 (permalink)
JRMichler's Avatar
The top is two layers of underlayment luaun (sp?) plywood nominally 1/4" thick, but actually 3/16" thick, so the total thickness is 3/8". The sides are one layer of that plywood because the spans are shorter. Years ago I built a topper with one layer of 1/4" fir plywood. That one sagged between the ribs after a year or two.
All joints were glued with Titebond II or III or whatever. It's the latest and greatest Titebond.
After sanding and filling defects with Bondo, I sealed with one coat of West System epoxy. I buy it in the gallon resin / quart hardener size and leave the pumps on the cans. I use the 206 slow hardener. I've been buying it from Aircraft Spruce.
Sand off the high spots, spray on some sandable primer, use up a whole tube of spot glaze, finish the second spray can of sandable primer, and brush on gloss enamel from the local hardware store. Wet sand the enamel, brush on another coat, repeat until sick of painting, put on truck. Done.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
BamZipPow (06-04-2011), slowmover (06-11-2011)
Old 06-03-2011, 07:13 AM   #20 (permalink)
Recreation Engineer
KamperBob's Avatar
I agree - looks nice. Linking pix here for convenience.
Short of your own thread it would be good to know about how much it weighs. Also what MPG difference with versus without the cap.
Recreation Engineer
